Torque Management and MAFT readings
Old Jun 13, 2002 | 09:36 PM
Dr. Jeckel's Avatar
Default Torque Management and MAFT readings
Does TM cut the engine a bit when shifting or what? Is converter lock-up when it shifts into 3rd good for a daily driver/strip car? Also....I have great readings with my current setup on A-tap. I plan to add the MAF ends to my stock sensor after i get Ls1edit. Anybody have a good starting point for Ltrims,A/F ratios.... and other affected tables? <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old Jun 14, 2002 | 03:11 PM
Sparky's Avatar
Default Re: Torque Management and MAFT readings
TM, when activated, will take out timing and fuel.
You want your Ltrims slightly negative.
Mark
