Edit experts or puter geeks out there.. need info on error code
Old Jun 17, 2002 | 12:17 AM
98TAauto's Avatar
Default Edit experts or puter geeks out there.. need info on error code
I get this code when clicking on edit.. the LS1 Pro file works fine though
Run Time error '339':
Component 'tabctl32.ocx' or one of its dependencies not correctly reegistered: a file missing or invalid
any ideas?? I just got a new laptop and im trying to transfer edit to it.. as far as i know i have all of the files in the same folder..
anyone know what that error code is?
when i click on LS1 program it works, but when clicking edit i get that?
Old Jun 17, 2002 | 12:27 AM
kent's Avatar
Default Re: Edit experts or puter geeks out there.. need info on error code
Good luck buddy, wish I could help you, but I can't on computer stuff yet. Now I know why you run such fast times--you fine tune the PCM--just kidding. Kent
Old Jul 5, 2002 | 03:30 PM
Jax White TA's Avatar
i'm getting the same thing. what gives?
Old Jul 5, 2002 | 03:54 PM
horist's Avatar
what OS?
Have you searched for the file (start -> search or find) ? Does it exist?
Here's some info I found
http://www.windows-hq.com/Download/w...eFAQs.cfm#err1
http://www.ascentive.com/cgi-bin/cli...nloadList.html
and straight from microsoft
http://support.microsoft.com/default...;en-us;Q289493
THE MS one is based if you're using a version of windows that allows for file level security...
Try the above two first (missing file, download and install)
Old Jul 5, 2002 | 04:08 PM
Chris Bratvold's Avatar
You said copied the files from your old laptop? Do you mean you just copied the LS1 Edit directory to the new laptop?
If you did that is your problem. Programs need to register with Window's before they are considered valid programs.
Run the LS1 edit setup program on your new laptop and you will be okay.
Old Jul 5, 2002 | 04:27 PM
horist's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris Bratvold:
<strong>You said copied the files from your old laptop? Do you mean you just copied the LS1 Edit directory to the new laptop?
Run the LS1 edit setup program on your new laptop and you will be okay.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Damn, stupid me, hehe, I didn't read the post all the way...
Yea, Chris is 100% correct, reinstall LS1 Edit. Windows software isn't like DOS Software ... certain files are stored in different directories so you can't just copy folders... you need supporting files too
