AutoTap Logging
2. Throttle Position Angle
3. Knock Retard
4. O2 Sensor B1S1 (volts)
5. O2 Sensor B2S1 (volts)
6. Fuel Trim Cell
7. LTerm fuel trim B1
8. LTerm fuel trim B2
ECT...
Just remember that Autotap will not log very many parameters very quickly.
@WOT I usually monitor some combination of:
RPM
BIS1 O2
B2S1 O2
TIMING
KR
........for tuning.
Throttle position is handy for M6.
Sometimes I monitor other parameters if I'm trying to get shift points, etc.
LTERMS I would monitor at cruise. Since your not so concerned about the update rate at cruise, you can stick a bunch of parameters in: Trans oil temp (A4), lterms, ECT,IAT, etc.
The more you use it the better idea you'll have what parameters to watch based on what you're concerned with.
