WTF kinda code is this
Old Jun 21, 2002 | 03:50 PM
BYBYC5's Avatar
*Bad Trader*
Default WTF kinda code is this
Manufacturer DTC DTC Title
General Motors P1380 EBTCM DTC Det. - Rough Road Data Unusable
dont know when i got it but it was there when i checked the coded today!!!!!
Old Jun 21, 2002 | 09:01 PM
RTCamaroSS's Avatar
Default Re: WTF kinda code is this
According to the SES translator on this page, you have a misfire.. but it doesnt specify where.
Old Jun 21, 2002 | 10:11 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
From memory: if the pcm (via crank sensor) detects what it thinks is abnormal crank rotation, it sets a code thinking it could be a misfire. According to the Helms, this could be caused by a rough road. I guess with a certain rotational time of the engine expected by the pcm ,and the wheels leaving the ground and then re-engaging, the engine speed varies enough to make the pcm think there could be a misfire. Not sure what all parameters it takes into account.
Clear the code and be on your merry way, AFAIK.
Old Jun 21, 2002 | 10:13 PM
BYBYC5's Avatar
*Bad Trader*
i cleared it and found #1 wire was loose, hope that was the problem..... we'll see soon..
