What does the PCM do when the airbags deploy
1) When the airbags deploy, does the PCM shut down the engine?
2) Like #1, after the wreck, will the PCM allow restart, or does it set an interlock of some sort that inhibits restart?
3) If I buy a used 98, and configure the drivetrain similar (I have Ed Wright custom programming), I'm assuming that the PCM from the wreck can be used. Am I correct?
Thanks!
I dont know the answer, but I would assume the PCM has nothing to do with the air bags...
I think the air bag controls are seperate (going through the PCM would be too slow). Sensors in the car that detect a collision and the speed of collision and then deploy the bags seperate of the PCM.
Also I dont see any safety or air bag leads into the PCM
