ls1 edit and auto-tap questions
Old Jun 23, 2002 | 11:32 AM
BADWS6's Avatar
Default ls1 edit and auto-tap questions
I have never used ls1 edit and i have been reading about it a lot and i was wondering if it would be good for a bolt-on car.What will i need to use ls1 edit and how much does it cost and where can i get it at.
Also about auto-tap, what do i need to use that and how much does it cost and where can i get it at.
Old Jun 25, 2002 | 11:04 PM
horist's Avatar
Default Re: ls1 edit and auto-tap questions
LS1 Edit:
Cost: 550 single user
Get from: www.carputing.com
Good for bolton car: Depends on the bolt ons and what you want to do... it's great for an auto... also you can control fan speeds, rev limiter, idle, etc...
Autotap
Cost: 200+ (forget exact amount)
Get From: My preferred vendor/sponsor is Speed Inc (http://www.ls1speed.com/) but I believe most of the sponsors here carry it
To run both a laptop is required... I'd say 133Mhz Pentium would prolly be fast enough
Old Jun 26, 2002 | 06:46 AM
Camaroholic's Avatar
133MHz Pentium is the minimum for LS1_Edit. It is designed for use with that level of Pentium chip and higher. So don't try to run it on a 486. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-Andrew
Old Jun 27, 2002 | 12:07 AM
red ws6 99's Avatar
Actually carputing changed there minimum to a pentium 200.
Gary
