Airbag light stays on constantly
Old Jun 27, 2002 | 12:25 AM
5150Z28's Avatar
Default Airbag light stays on constantly
I had no idea where else to post this. I removed the steering shaft to grind it down a little bit because it was rubbing up against the MAC's and now this damn light won't go out. I reset the pcm and it still comes back (along with the check engine light). Any advice on how to handle this is greatly appreciated.
Old Jun 28, 2002 | 05:08 PM
5150Z28's Avatar
Default Re: Airbag light stays on constantly
ttt
Old Jun 28, 2002 | 08:32 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Have you checked the pcm for codes? Off hand I can't think how anything related to clearancing the steering shaft could cause a problem with the airbag electronics.Is it clearing the headers ok now?
Old Jun 29, 2002 | 01:13 PM
99LS1_TA's Avatar
Did you leave the key in the locked postion or did you have it in the on postion and rotated the steering wheel? If you rotated the steering wheel more 3 turns while the steering shaft was disconnected you probably broke the clock spring in the column.
