TBYRNE Has LS2 Predator Programmers Coming!!!
U7191 2005 GTO/C6 Predator programmer with overnight shipping $399.99. This price includes FREE overnight shipping in the 48 states!
Have a good day!
ORDER LINE - 1-877-4-TBYRNE (1-877-482-9763)
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE FOR CURRENT SPECIALS!
WE HAVE YOUR FORCED INDUCTION NEEDS COVERED WITH - ATI, VORTECH AND MAGNUSON SUPERCHARGERS ALONG WITH STS TURBOS!
*Predator supports:*
2005 Corvette
2005 Pontiac GTO
2005 SSR
*Included tunes:*
Performance Tune
Factory HP Tune
Ability to hold one (1) custom tune.
Predator will unlock upon original backup restore.
Read and write time is about 30 seconds respectively.
*Adjustable parameters:*
*Applied fan power vs ECT*, +/- 20%,
Allows adjustment for fan power based on ECT(engine coolant temp)
*CAGS ON/OFF*, on/off
Allows to enable or disable CAGS(skip shift)
*COT time delay*, 0-60sec
Allows to control the amount of time before entering COT, catalytic overtemp protection which adds fuel to cool the converters off, if no cats are present the COT on/off parameter can be used to completely turn this function off.
*COT ON/OFF*, on/off
Allows to turn the COT(catalytic overtemp protection) strategy completely off, for vehicles with no cats.
*Idle drive*, +/-400rpm
Allows for adjustment of idle when in drive.
*Idle park/neutral* +/-400rpm
Allows for adjustment of idle when in park/neutral.
*Injector slope*, +/-40%
Allows to correct fuel trims via injector slope
*WOT fuel 2k-3.8k* +/-20%
Allows for WOT fuel adjustments in the 2000-3800rpm range.
*WOT fuel 4k-7k*, +/-20%
Allows for WOT fuel adjustments in the 4000-7000rpm range.
*Rev limit in drive*, +/-400rpm
Allows for adjustment of rev limit in drive.
*Rev limit in park/neutral*, +/-400rpm
Allows for adjustment of rev limit in park/neutral.
*WOT spark 1k-1.8k*, +15/-40%
Allows for WOT timing adjustment in the 1000-1800rpm range
*WOT spark 2k-3.8k*, +15/-40%
Allows for WOT timing adjustment in the 2000-3800rpm range
*WOT spark 4k-7k*, +15/-40%
Allows for WOT timing adjustment in the 4000-7000rpm range
*Diagnostics*
Retrieve and clear DTC’s.**
Monitors and logs live data.
I have confirmed that a shipment is heading this way!
