LS1edit Questions form a Newbie......
Old Jul 9, 2002 | 07:26 AM
Jadeeglide1550's Avatar
Default LS1edit Questions form a Newbie......
I just fired up my LS1edit program after scanning the PCM. My car has the M6, and I assume that when there are Spark Advance in Drive and Park, that for the M6 the readings are identical. Is this true?
Also, I thought that I had read that it is possible to access individual fuel cell readings and modify them, is this true? For example, can you modify any of the Number 1 thru 9 Fuel Cells that Atap shows or do you just make adjustments to the injector and MAF readings to adjust in the setting for the Ltrims?
Would appreciate any help on using the LS1edit... being a Newbie with this... so to speak.
Old Jul 10, 2002 | 01:17 PM
Default Re: LS1edit Questions form a Newbie......
I think thanks to some of the other posts I have figured out what is going on. Accessing the fuel cells is a little different in LS1 Edit than what is seen in Atap. Anyway... on to bigger and better power as they say....
I want to thank me for replying to myself... LOL
Old Jul 11, 2002 | 03:25 PM
Predator's Avatar
I just wanted to thankyou for replying to yourself <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> .
