Very little advance at wide open throttle
Old Jul 10, 2002 | 02:35 AM
SoCal LS1's's Avatar
Default Very little advance at wide open throttle
I just put headers on and am only getting 28 degrees of advance at wide open throttle everything else looks good except my ltrims which are a little on the lean side. Anybody know whats up or what this could be.
Thanks
David
Old Jul 10, 2002 | 07:53 AM
Jax White TA's Avatar
Default Re: Very little advance at wide open throttle
Unless you have some kind of tuning, 28 is stock advance for early LS1's. Later ones are even less. Even if you have tuning, with 93 octane only about 30º is possible.
Old Jul 10, 2002 | 06:11 PM
Is this only at wide open throttle because I get more when rolling on it not wide open. Like between 33 and 40.
David
Old Jul 11, 2002 | 12:00 AM
ZR 900's Avatar
The 28 degrees you got was at what RPM and at what gear at WOT? The reason I ask this is because I get 22 degrees at 5500 RPM in 4th gear at wot and I am running rich.
