Any ideas on what would cause such large deviations between the O2s?
I have a 12" o2 extension on the driver's side, and no extension on the passenger side (just yanked the wires out of the harness to make them reach, hehe).
Could an O2 be damaged? Or the wiring?
I don't think there's any leak at the flange (where the headers attach to the head) as there is no ticking or anything like that, and I would assume an exhaust leak that close to the engine would be very loud.
Any ideas?
Thanks
Dope
TTT for you. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Bad30th
Dope
Swapping fuel injector banks can also be done to try to isolate the problem if it turns out not to be O2s.
Free stuff is always good to test first. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Also FWIW it's normal to have a little variance between the two banks, and it's more common to have a wider variance if you're tuned to positive LTrims (i.e. lean). Supposedly going into negative LTrims evens the two banks out somewhat.
Tuning with the MAFT seems to have two camps :
1) Tune to +8/+10 LTrims and gain a few degrees of timing
2) Keep slightly negative LTrims for more even O2 banks and no fuel enrichment at WOT, no gain in timing but more even tuning
Most have said that the extra few points of timing gained by camp #1 haven't shown any gains above camp #2 tuning, and that having the ECM arbitrarily adding fuel from the last known LTrim at WOT is a bad idea.
I am getting Ed Wright programming next week with my heads/cam upgrade and will be interested to see where the fuel trims are afterwards.
Good luck,
Bad30th
