Help with LS1 edit please.
I installed a cam and aftermarket heads on my C5 and have a couple of questions about LS1 edit.
I have been playing around with it for about a week and am really lost. First off, how do you adjust the a/f and quality of the idle? I set the rpm and now the car stalls and hunts for idle when warmed up. I did the idle relearn and it didn't help.
Second question is, how do I adjust the a/f ratio at part throttle? I played around with the MAF settings but that made my WOT a/f ratio so far out that the PE vs. RPM table couldn't compensate. The best I could get WOT was 11:1 a/f ratio. So I figure I am adjusting the part throttle wrong.If not in the MAF table, what table do I make adjustments in?
Any help is appreciated.
What are your IAC counts at idle? They need to be 30-50, preferably around 40. If they're higher than that, you probably need to make the hole in the throttle body blade very slightly larger. Like 13/64" or somewhere just slightly larger than the hole that's there. The amount that you need to tweak the hole depends on the number of steps that the IAC motor is out. If it's at 140, you'll need to drill bigger than if it's at 90.
HTH,
Andrew
Check this link www.ls1edit.com/pipermail/ls1edit/
there was a lot of information about this topic in the last couple of day's
