how to raise shift points on edit??
Old Jul 18, 2002 | 07:44 AM
98TAauto's Avatar
Default how to raise shift points on edit??
ok i was looking and it has 2 features..
ones the rpm shift point then they have the MPH ones for each shift??
which do i change? the rpm or the MPH?? or both??
Old Jul 18, 2002 | 08:09 AM
JNorris's Avatar
Moderator
Default Re: how to raise shift points on edit??
On my 98 if I want to raise the 1-2 shift 1 MPH I add 129RPM to the 1-2 RPM and 1 MPH to the speed. For the 2-3 I add 69RPM and 1MPH for each MPH I want to change the shift to.
With 3.23 gears and a stock size tire I use the following table.
Shift Points Link
However I thought that with Ls1 Edit V1.05 you could set the shifts to take place after both the MPH and RPM settings were met.
John
<small>[ July 18, 2002, 08:14 AM: Message edited by: JNorris ]</small>
Old Jul 18, 2002 | 04:19 PM
98TAauto's Avatar
they have a normal, hot, and perf mode
im guessing i just change the PERF??
but i was wondering if i could just like say change the shift rpms and not mess with the mph and that would work?? or did i have to change both?
Old Jul 18, 2002 | 04:33 PM
JNorris's Avatar
Moderator
It is my understanding that the Fbody does not support the Performance Mode shift parameters.
See below link for what I have done with my shift
points.
https://ls1tech.com/ubb/ultimatebb.p...;f=23;t=001776
John
