LS1 Edit Problem
Old Jul 19, 2002 | 03:08 PM
DravenMyers's Avatar
Default LS1 Edit Problem
I can't get the program to start. I was e-mailed the first two files, but didn't get the third one. When I try to open it, it says "Invalid command-line parameter unable to continue" <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Is it because I don't have the third file. Isn't the third file just a user guide? Thanks in advance.
Old Jul 19, 2002 | 03:13 PM
DenzSS's Avatar
Default Re: LS1 Edit Problem
You need all 3 fiiles. 2 cab files and the zip.
Old Jul 19, 2002 | 04:20 PM
Thanks DenzSS. I went to their webpage and downloaded "ls1edituserguide.zip". Is that the right one? The other two that I have are "LS1_Ed1.CAB" and "LS1_Ed2.CAB". I tried starting it again and this came up...
WinRAR: Diagnostic message
C:\\WINDOWS\Desktop\LS1EDIT\LS1_Ed2.CAB: Cannot open LS1_Ed3.CAB
Old Jul 19, 2002 | 04:25 PM
Team ZR-1's Avatar
No the user manual is not the 3rd file, it is another zip file.
If they are doing the same process, they send you the 1st two zip files and do not send the 3rd file until you receive their hardware interface.
Is that the state your in?
If not you have to e-mail them and tell them which zip files you did get so they can resend missing zip file.
Old Jul 22, 2002 | 03:38 AM
1dirtyZ's Avatar
don't forget that these are huge files even after zipping, they could have sent you the the three files in order but your third one didn't come through cause youe email account was full.
