possible to delete or disable knock sensor?
Old Jul 21, 2002 | 03:49 PM
Ben99Z28's Avatar
Default possible to delete or disable knock sensor?
Just wondering if we can disable our knock retard sensor with LS1 edit, any ill effect by doing so??
Old Jul 21, 2002 | 03:59 PM
Toxic Texan's Avatar
Default Re: possible to delete or disable knock sensor?
You can make them less sensitive. I am not sure on turning them off.
<small>[ July 21, 2002, 04:01 PM: Message edited by: Toxic Texan ]</small>
Old Jul 21, 2002 | 04:03 PM
Predator's Avatar
With LS1 Edit, you can turn off codes P0325 (ks circuit) and P0332 (rear ks) which disables the system.
Old Jul 22, 2002 | 04:30 PM
MIGHTYMOUSE's Avatar
i have tried that, i get the 332 code, i can delete the dtc light, but it still retards the timing 4*
i can put all the kr tables to 0, still pulls 4*
i can add 4* to wot, and it pulls 4*, and im back to normal..
thats my problem with the rear knock circuit.. o332
Old Jul 22, 2002 | 05:20 PM
Predator's Avatar
I just assumed that the ks system was disabled, I didn't scan my car after doing that, so it was probably pulling 4 degrees of timing on me too (I just drove leasurely around the block). I ended up replacing my knock sensors, harness, and RTVing around the rubber boots.
Old Jul 23, 2002 | 11:40 PM
SIKLS1's Avatar
Oz Director
P0327 is missing in LS1Edit on 99-00 version you need to turn off all 3 to make it work.
<small>[ July 23, 2002, 11:41 PM: Message edited by: SIKLS1 ]</small>
