Truck not running right, need help!!
why) and the engine starts and revs high, but doesn't sputter during the 2 seconds of initial startup. It just starts and revs high. I plug the MAF back in and the sputtering comes back during the first two seconds of running and then revs high. I then start it up again and see how high it will rev, well it stops around 4000rpm's and then cuts back and the goes up to 4000rpms and then cuts back, it keeps doing this like I'm revving it up to 4000rpms then letting it come down to 3500rpm's, then back up. The only thing I did since the last time I turned it off and this morning was remove the 4" round, plunger type thing from the passenger side trans to remove a couple of shims. Actually, I never really removed it, I got the snap ring out and then couldn't pull it out by hand, so I just put it back together. (my tranny is shifting too hard). I don't think that had anything to do with it.
any ideas? thanks in advance
allen
http://www.ls1truck.com
<small>[ July 22, 2002, 10:40 AM: Message edited by: AllenSSilv ]</small>
