EFI Live Question
Old Jul 22, 2002 | 05:49 PM
MilDot's Avatar
Default EFI Live Question
Can I use this on both my 2000 Z-28 AND my 2001 5.3L Yukon???
For monitoring and/or altering:
fuel curve?
spark advance?
idle speed?
top speed limiter?
shift points?
Is there any limit to the number of vehicles I could use this on?
Sorry about the questions, but I'm wondering if this is the software I'm looking for...
Old Jul 22, 2002 | 08:45 PM
EFILive's Avatar
Restricted User
Default Re: EFI Live Question
EFILiveV5 is only certified for GM vehicles fitted with the LS1 engine.
The adjustments that you can make with EFILiveV5 Pro are temporary and will revert to factory calibrations if/when EFILiveV5 is disconnected.
You cannot make adjustments with EFILiveV5 Std.
If you want to make permanent adjustments you will need something like LS1Edit.
Adjustments can be made while the engine is running so you can observe/measure the performance gain/loss immediately.
fuel curve?
Monitor and/or adjust
spark advance?
idle speed?
top speed limiter?
No
shift points?
No
No - all versions of EFILiveV5 are unlimited.
EFILiveV5 FAQ:
http://www.starrperformance.com.au/e.../faq_index.htm
More information on bi-directional controls:
http://www.starrperformance.com.au/e...trol_index.htm
Regards
Paul
