Every so often get p0102 code - MAF Sensor Circuit Low Frequency
Old Jul 23, 2002 | 05:56 PM
5150Z28's Avatar
Default Every so often get p0102 code - MAF Sensor Circuit Low Frequency
A while back when I had ported maf ends I got this code so I swapped the stock ends back in (minus the screen). The car has been running fine for months until recentely. For the last few weeks this code has been getting set and on occassion when driving around the car will hesitate for a split second and pick back up again. Has anyone else had this issue? I'm looking at getting an aftermarket calibrated MAF to see if this alleviates the issues but would like some input before I spend the cash.
*Note - the only code being stored in the PCM is P0102*
TIA for any help.
