Correction factors & Dyno readings?
SAE, DIN, EEC, STD & Uncorrected.
What do they all mean and what one would I use?
I Dynoed @ 351 Uncorrected
@370 Using SAE
@387.74 with STD
What is the correct reading?
It was 98.71 degrees (inside at the dyno) and I the humidity someplace in the 80%
Uncorrected is what your car is actually putting to the ground. No correction for Temp, Alititude, Barometric Pressure, etc.
SAE: The Standard
STD: Older Standard
