New Injectors...
Old Jan 16, 2006 | 03:21 AM
LoWeLL216's Avatar
Default New Injectors...
I've got a set of SVO 42lb injectors that I'm putting in, but I'm not sure how to tune them. I've also got a racetronix fuel pump. I've got a copy of Redhardsupra's injector worksheet, but I'm not quite sure what to plug in. Injector Rated Fuel Pressure - Is this what Ford tests the injectors at?, and what is it? (I've seen several), Fuel Rail Pressure - Is mine still 58 psi even with the new fuel pump?, and Injector Rated Flow Rate - Is this just 42lb? Is there anything else I need to change after the install? Thanks everyone!
Old Jan 17, 2006 | 04:17 AM
LoWeLL216's Avatar
ttt...
Old Jan 17, 2006 | 09:28 AM
ninobrn99's Avatar
if you go to his website, he has the values you need already there. I had problems with the worksheet also. Its as simple as copy and paste.
Old Jan 17, 2006 | 09:47 AM
WS6FirebirdTA00's Avatar
if not let me know i have the values, he actually got that spread sheet from me
Old Jan 17, 2006 | 09:49 AM
ninobrn99's Avatar
mike! dude, what up!? hey, hows the bucking come along since you installed the WB??
