Ls1Edit tunning with HotCam?
Old Jul 28, 2002 | 12:42 AM
Dr. Jeckel's Avatar
Default Ls1Edit tunning with HotCam?
I'm about to install the GM HotCam and was wondering if i need to change up any tunning besides shiftpoints & idle. I have the HPP3's tunning in my Edit file as well as some other changes. My (high octane) advance is set to 30 under WOT, should i make it higher? Do i need to turn off any missfire codes? Any body done this cam with edit before? if so please give advice. Thanks, James.
p.s. any chance of having bad E.T. streets? I used a buddies last night(26x11.5x16) and i received 2.13 60fts at 13psi even with heating them up.
Old Jul 28, 2002 | 04:50 PM
Dr. Jeckel's Avatar
Default Re: Ls1Edit tunning with HotCam?
You mean no one has got the Hot Cam and using edit? Even a link or name of some one will help. Thanks, James. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Jul 28, 2002 | 05:08 PM
JNorris's Avatar
Moderator
Try the following links.
http://ls1edit.slowcar.net/
http://www.ls1edit.com/
Both sites have LS1Edit flash files for download.
John
