Torque Converter Lockup ???
Old Jul 30, 2002 | 06:45 AM
PAULJ99Z's Avatar
Default Torque Converter Lockup ???
Lately, I have been having random unlocking problems on the freeway and cannot understand why. Listed below are the mods:
Stock Tires
3.42 Gear (3.23 stock)
LS6 Cam
LS6 Intake
Mac Headers
No Programming
ASP Pulley
Could it be the 3.42 gear causing problems with the desired MPH or RPM's? Seemed like it started having problems after I removed the Hypertech Tuning which I had a correction for the gear ratio. Would LS1 Edit fix the problem? Thanks
Paul J.
<small>[ July 30, 2002, 06:46 AM: Message edited by: PAULJ99Z ]</small>
Old Jul 30, 2002 | 06:52 AM
WILWAXU's Avatar
Default Re: Torque Converter Lockup ???
Yes LS1 edit will help resolve that problem.
Moving to Computer Tuning section.
Old Jul 30, 2002 | 11:56 AM
Ragtop 99's Avatar
There are number of potential issues that could be causing lock-up problems that Edit can solve.
Old Jul 30, 2002 | 06:08 PM
PAULJ99Z's Avatar
I forgot to mention I have a PI 2800 Vigilante. It was working fine on the highway until recently after deletion of Hypertech programming. At times, under long idle times, the converter will refuse to lock for several miles. Will Autotap show misfires that can lead to lockup problems?
Old Jul 31, 2002 | 12:09 AM
ChrisB's Avatar
You won't get a definite answer untill you have diagnosed the problem. You need some sort of scan tool (autotap, ease, efilive, etc.). Once you can scan your car you can get an idea of what the problem is - once you know what is causing your problem then it can be determined if ls1 edit can fix it.
Chris
Old Jul 31, 2002 | 12:33 AM
Ryan K's Avatar
Pathological Modifier
Do you have an aftermarket torque converter? If so, that may be causing the computer to have fits with misfires. The misfires can cause the TC to unlock. LS1 edit can fix that.
Ryan K.
Old Aug 10, 2004 | 09:53 AM
Rays C5's Avatar
Yes ,Autotap shows misfires.I have the same problem.Have changed misfire temp. detection,put in 326767(I think those are the suggested numbers) and still have converter unlocking issues.At the same time it codes saying trans slipping???? Anymore suggestions??? not hijacking, just looking for enlightening
