MAF?
Old Aug 1, 2002 | 10:22 PM
Will's Avatar
Default MAF?
Hey guys I was wondering if I had to tune the MAF button under Fuel in Ls1 Edit if I did an injector swap from 24lbs to 30lbs??? Let me know what you guys think and if I have to how would I go about doing it???
Old Aug 2, 2002 | 12:01 AM
ChrisB's Avatar
Default Re: MAF?
When changing injectors your best bet is to change the injector constant (flow rate for sure, and injector offset if you have that info).
Chris
Old Aug 3, 2002 | 12:33 AM
Will's Avatar
Default Re: MAF?
I changed from 24lb stock injectors on my 2000 silverado with the 4.8L and I went to the stock 8.1L injectors..... I changed the injector constant but not the offset. My first question is... Do you all think that the offset tables would have to be changed for these different injectors since they are both coming from stock Gm engines.... The next question is would NOT changing the offset table make it mix lean???? And finally, my original question would I have to change anything in the MAF button?????
Old Aug 3, 2002 | 11:16 AM
Will's Avatar
Default Re: MAF?
Anyone?
