Race Fuel
Old Jan 17, 2006 | 09:54 PM
Dmoney's Avatar
Default Race Fuel
Do I have to retune anything if I put a little bit of 104 octane?
Old Jan 17, 2006 | 10:02 PM
white2001s10's Avatar
It depends completely on why you're putting it in.
The norm is to tune for the octane or more precisely the burn-speed you have.
If you're putting it in to slow burn speed, then you don't neccessarily need to do anything. Raising octane is a fairly good form of protection/insurance for the engine, but it is normal to lose some power unless the tune matches the octane.
Some high octane fuels also have higher specific gravity or density so that also will change tuning requirements.
I could better answer if I knew why you were using the extra octane.
Old Jan 17, 2006 | 11:03 PM
Dmoney's Avatar
I just want to know if it will help out at the dragstrip.
Old Jan 17, 2006 | 11:24 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Unless it is heavily oxygenated and you retune for it, it won't help your times at stock compression n/a. You can't just look at octane ratings, you also have to look at fuel composition. Some have a lot more oxygen than others.
Old Jan 17, 2006 | 11:31 PM
Dmoney's Avatar
I'm at 10:8:1 compression and the race fuel is Sunoco 104 and if I do use it what do I need to change in the tune?
Old Jan 18, 2006 | 03:59 AM
BlackHawk T/A's Avatar
Not sure but IMO if you don't get any detonation on the fuel you run now the 104 won't help you at all...
Old Jan 18, 2006 | 08:54 AM
You will most likely run slower with the 104.
It would take some tuning time on your part to determine how much to raise the SA and possibly reduce the AFR until the tune matched the 104 correctly, but then you'd probably be back to where you started performance wise.
In general, only engines with increased DCR or cylinder pressure can take advantage of race fuel.
