Check engine light on. Need help with codes.
Old Aug 6, 2002 | 09:35 PM
jimmie's Avatar
Default Check engine light on. Need help with codes.
I pulled codes 410 ,412, and 418. He said they were all air induction related. Anyone else pull these codes or now the cure for it. Thanks. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Aug 6, 2002 | 11:20 PM
RTCamaroSS's Avatar
Default Re: Check engine light on. Need help with codes.
All of those codes are related to the Air Injection system... first one is a blanket code saying there is a problem in the AIR system, second is a relay control problem in bank 1, and the last one is a pump relay problem on bank one.. Did you happen to remove anything lately? Id start checking connections and check the relays in your fuse block, make sure everything is there and working.
