someone explain map and psi for me!!
when scanning with an ease scanner the map sensor shows 47 kpa at idle and 27 kpa when engine breaking and 104 kpa ( map sensor limit) under wot. i also have a blower on the car.
so if i figure this correctly , 0 psi from the blower equates to 47 kpa , but what does 104 kpa equal to in terms of psi ??
when converting 100 kpa is equal to 14.5 psi which doesn't make sense, cause i have the 7 psi kit and i see 7 psi on the boost guage.
do i just subtract the 47kpa that is at idle?? <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
