Edit gurus: how to add timing at low rpms??
Old Aug 10, 2002 | 11:28 AM
98TAauto's Avatar
Default Edit gurus: how to add timing at low rpms??
i just got the cam installed and would like to know what do i pull up on edit to change my timing a few degrees in park and drive in the lower rpms??
i have a little stall issue on warm starts and i believe this may fix the issue. I turned my set ket around and drilled my throttle hole to 20-40 range already also. Rpms at idle are 900 too.
Old Aug 10, 2002 | 01:07 PM
Sonny's Avatar
Default Re: Edit gurus: how to add timing at low rpms??
check out:
http://ls1edit.slowcar.net/tuning.html
Old Aug 10, 2002 | 11:42 PM
Brother J's Avatar
Here's what I did. It helped quite a bit.
Get into LS1Edit
-Engine Cal
-Ignition
-Base spark in drive/park
find the rpm columns 800 and 1200
fill in the blocks for the first 4 rows (0.08-0.2 Gm/cyl) of the 800-1200 columns with the value of 25
