Ideal air/fuel ratio
Old Aug 10, 2002 | 11:37 PM
Juiced LS1's Avatar
Default Ideal air/fuel ratio
Just wondering the ideal air fuel ratio. Want to change the stoich if need be. Thx
Old Aug 10, 2002 | 11:52 PM
Brother J's Avatar
Default Re: Ideal air/fuel ratio
Leave stoich at 14.7.... Get your LTrims in trim cells 1-15 to avg close to 0 favoring the negative side. Then get your WOT O2's in the .88-.89 range. Then get hooked up to a wide band and see what your A/f is. I think you want to shoot for ~12.8 max rich at your torque peak, but you want to talk to the dyno operator about that because the dyno's are usually calibrated for a 3000lb car and ours weigh ~3600lbs.
Old Aug 11, 2002 | 12:01 AM
Juiced LS1's Avatar
Well thank you!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
