Need help with SES light code PO300
They know about my mods like the 3300 stall converter I have and they are cool about it. I had that converter installled as soon as I bought the car last Feb. The only problems I have had with that is, at idle sometimes the car would try to die on me, but just every now and then not offten, and around town at lower speeds I would have to have the car in 3rd. gear because the car would not down shift right.
From reading post on here I came to believe the downshifting problem was caused by false misfire. The SES light never came on.
One of the last mods I did was the cutout (mods in sig). Not long after the cutout, the downshifting problem got better and better, untill I could drive it in overdrive again without any trouble. Don’t know if it has anything to do with the cutout or not.
My husband and I have never reset our computers after all the mods we have done. The guys at the dealership told him to disconnect the neg. Battery cable then the pos. Cable. Let it sit 10 min. Then hooked it back up the neg. Cable first, then pos. Start car let run for a min or 2 then turned on the a/c. Then turn car back off, waited about 10 min. Then drove car around for a while.
Worse thing I have done to my car, it hasn’t been the same again. I could hardly keep the car going at idle. When I was slowing down to make a turn the car would die on me. Did that for a couple of days, then the SES light came on. That’s when I took it to the dealer and they replaced the computer. Didn’t get 2 miles down the road and the light came back on again. And it still dies on me if I don’t keep the rpms above 1000 or so.
I tried to reset it again by removing the 2 fuses in the engine comparrtment with the key on, let sit a few min. Turned key off, replaced fuses. After a few miles down the road the light came back on. Did this 2 times.
I believe it has something to do with the torque convert and need to tune the pcm. I ordered LS1 Edit, please help me on what to do with it.
Sorry this post is so long.
Thank-you, Becky
James
<strong>It sounds like your car is cammin hard, even though you don't have one <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Alot of us cammed folks go through what you are talking about. Do you have autotap? If so, what is your IAC count? If you turn the air conditioner on, will the car run normal, or does it die?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't have autotap yet, so I don't know what my IAC count is. The car runs rougher when the A/C is on.
<small>[ August 11, 2002, 01:01 PM: Message edited by: NoGo ]</small>
