Injector Constant question ?
Old Aug 13, 2002 | 02:34 PM
WicketMike's Avatar
Default Injector Constant question ?
ChrisB or anybody else that knows
do i need to mess w/ the Injector Constant if i have stock injectors?
and if it does help to mess with the constant what do i look for on A-tap to make sure i do it right on LS1Edit
thanks
Old Aug 13, 2002 | 09:14 PM
WicketMike's Avatar
Default Re: Injector Constant question ?
ttt
Old Aug 14, 2002 | 10:38 AM
MIGHTYMOUSE's Avatar
you can change it to adjust afr, but makes more sense to do it with the maf table or pe vs rpm
doing it with injector flowrate is like telling your car it has larger/smaller injectors and trimming the fuel that way.
Old Aug 14, 2002 | 01:22 PM
WicketMike's Avatar
ok, so i dont mess with that until i get bigger injectors.
thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 14, 2002 | 05:11 PM
cablebandit's Avatar
exactly but you can still trim your wot pe/rpm and try to pick up a little there
Old Aug 14, 2002 | 11:25 PM
ChrisB's Avatar
Everyone covered it! Leave the stock settings alone (for injectors). Change your WOT a/f ratio using the PE vs RPM table
Chris
