Raising Idle with LS1Edit
Old Aug 13, 2002 | 08:09 PM
DravenMyers's Avatar
Default Raising Idle with LS1Edit
How do I go by raising the idle speed with LS1Edit? The table shows idle for:
In Gear A/C off
In Gear A/C on
In Park A/C off
In Park A/C on
and on top it has the temperature. Do I adjust it by adding increments or do I put the idle I want throughout the whole table <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I hope this makes sense. Thanks guys.
Old Aug 13, 2002 | 09:32 PM
98TAauto's Avatar
Default Re: Raising Idle with LS1Edit
yep, the idle changes as those temps change on there..
i think you got the basic picture, but i just filled in what rpms i wanted and click save changes(dont forget that)
then save the file
i went across and set mine at 850 for the cam,
875 in gear
but you can use any rpm you want, just play with it and give it 10 mins to relearn
Old Aug 14, 2002 | 07:59 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I set all my values the same for all temps past like 40 degrees in and out of gear and with the AC on or off. I have a 800rpm idle with a B1 cam and I think my TB hole is 13/64ths. Seems to work well, even though my IACs are in the 60+ range. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I’m not worried about my IACs as long as I don’t get surging/stalling when sitting at stoplights and such...
