New to LS1edit...Rev Limiter???
Old Aug 15, 2002 | 03:01 PM
DravenMyers's Avatar
Default New to LS1edit...Rev Limiter???
How do you raise the rev limiter with LS1Edit? I tried the search feature and found nothing. Thanks in advance.
Old Aug 15, 2002 | 07:12 PM
98TAauto's Avatar
Default Re: New to LS1edit...Rev Limiter???
on the 1.1 version i'd just go to engine
then idle/limiters
then you will see a rev limit by gears and i just raised mine there
6600 then 6598 for turn off
Old Aug 15, 2002 | 08:00 PM
Thanks 98TAauto! I wasn't sure about the Resume RPM.
Old Aug 15, 2002 | 09:15 PM
98TAauto's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DravenMyers:
<strong>Thanks 98TAauto! I wasn't sure about the Resume RPM.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i just went by how the stock one was setup..
i figure the resume being set about 2 rpms lower would be fine since thats the way they have it.
but you can set yours however you want(beauty of edit)
then go try her and see if it worked <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
