NEED tuning advice Ltrims
Old Aug 16, 2002 | 04:41 PM
2002snortbird's Avatar
Default NEED tuning advice Ltrims
Ok guys here we go. I ataped my nuts off today and here is the results. At idle my avg ltrims are 16.8, with avg 21.5 degrees timing. At WOT my o2's avg .930, with 25 degrees of avg timing. shown no kr. Should I buy a MAF translator and make adjustments. Please give some feedback. thanks in advance
Old Aug 16, 2002 | 05:32 PM
LS1derfull's Avatar
Default Re: NEED tuning advice Ltrims
I would bring Ltrims down with translator, but be prepared to lean WOT settings down to make good power, been there done that. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 19, 2002 | 09:00 PM
I would like some more advice
Old Aug 19, 2002 | 09:09 PM
justin sutton's Avatar
I run my 02s around 890 900 wot & ltrims as close to 0 as poss.I set ltrims at idle & check em while driving down the road at part throttle.
Old Aug 20, 2002 | 04:46 PM
Brother J's Avatar
You want to have slightly negative LTrim in cells 1-15. Your WOT O2's will vary. I tuned mine for .890 and when I dyno'ed, it indicated an A/F of 13.5 from 3500 to 5500, then went to 13.0 from 5500 to 6500. This, obviously, was too lean and resulted in a 1st pull of 383.9 rwhp and 367.5 tq. For the next pull, I fattened up the PE/RPM table 5% and got my A/F down to a flat 12.5 accross the board. The result was 387 rwhp and 369.5 tq. Autotap on the way home showed my WOT O2's were in the .920 range. Each car will be different.
