EGR and AIR code ??
Old Aug 17, 2002 | 05:54 AM
oOoLy's Avatar
Default EGR and AIR code ??
whene i finsh install my new cam ( mms229 ) and delete the EGR and AIR .but i want to delete the code ??
note : i have the LS1-EDIT .
Old Aug 17, 2002 | 03:20 PM
Dr. Jeckel's Avatar
Default Re: EGR and AIR code ??
go into engine diagnostics and scroll down the list of codes. turn off the codes buy toggling through the bottom box and choose "X"-turn off code. Or something like that. the code will never give a SES light again. You can leave the code test toggled on though, or turn it off. If your car is an auto you will need to change a few more things to get the converter lock-up and raise the idle a little. Look at some posts that i have made on these things. Do search by "new cam, won't idle" in the internal engine section and "new cam, won't idle" in this section as well. Good luck, James.
