Need help with code P1514
Old Aug 18, 2002 | 05:55 PM
Leerph's Avatar
Default Need help with code P1514
Hey guys. I just installed my ATI D1SC on my 2000 vette and tuned with LS1 edit. The car is bone stock otherwise. Every time I get into the throttle I get code P1514 which triggers reduced power mode, service active handling and trac. control. I have done lots of research, and it appears this happens fairly often with FI vettes. I even saw where the new version of LS1 edit has an estimated airflow table to define expected airflow in regards to this code. I plan on calling carputing tomorrow to see if I am eligible to get the newer version or not. Anyway, what I haven't found is what to do with my tables in order to correct this problem. Could anyone give me any help as to how to get this beast on the road? Any help or suggestions are greatly appreciated. I have read until my eyes are bleeding. LOL!
Old Aug 19, 2002 | 08:39 AM
ToplessTexan's Avatar
Default Re: Need help with code P1514
Did you get squared away yet?
Old Aug 19, 2002 | 01:31 PM
ChrisB's Avatar
<img src="http://www.slowcar.net/dtc1514.jpg" alt=" - " />
Open that table and scale all factors by 200 percent - check for code, increase scaling if required!
(Don't know the first version this table came out in, but it is in 1.1)
Chris
Old Aug 19, 2002 | 11:21 PM
Leerph's Avatar
Thanx guys and especially to topless texan. I was screwed without the 1.1 version. Changed those values and I'm in business. Thanx guys.
