running too rich! need help please!
What do I need to do using Edit to lean out this car some!
I think the bulk of your problem is the MAF Failure. If your MAF fails, the PCM will use a totally different set of values for operating the car. This mode is called Volumetric Efficiency mode (I think). When in this mode, the PCM is basically doing a calculated crap shoot on how much air is getting into the engine. If you have aftermarket H/C or even just a cam, when running in VE mode, you will be excessivly rich. Additionally, all changes you make to the MAF tranfer tables will do ABSOLUTELY NOTHING because the PCM is referencing a totally different table on how much air is getting into the engine.
You need to fix the MAF failure first. Check all MAF wiring. Check the MAF plug. There is also an inline fuse for the MAF, unfortunately, I have never replaced it. Do a search for MAF failure, there have been several people that have blown this fuse.
Good Luck
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
In addition to what was posted above verify that your "Eng Sense" fuse is not blown.
Chris
