Another emissions thread!
https://ls1tech.com/ubb/cgi-bin/ulti...3;t=000268;p=2
https://ls1tech.com/ubb/ultimatebb.p...=002139#000000
https://ls1tech.com/ubb/ultimatebb.p...=001831#000001
They are checking to make sure all the tests are in a complete state and that there are no stored DTCs or MIL on. If you shut down the MIL no DTC will be set, but the test will run and show complete.
1)Pass and everyones happy
or
2)Blows the test so far out thier *** that a national bulletin gets put out to the smog ****'s so that every single Fbody gets run through with a fine toothed comb prior to inspection.
With my luck I will fall into the later category
Where it is true you could leave IM tests running but turn off the DTCs from tripping the MIL, EPA has caught on to that and there are tools that can send a DTC code to PCM and tester looks to see if MIL light went on as it should to check if the DTC was turned off.
There is also a tool that queries PCM to find out if it is the orginal PCM, is it the correct VIN, is the module ID valid, does the correct number of PIDs and I/M tests match for that model year to see if the owner is sneaking in another PCM that would pass smog.
What states, county, etc are or will use that tool is unknown but I'd bet within the next year they will be using them.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by NataSS Inc:
<strong>I have a 99 SS that will have MTI stage 2 Ls6 heads and and X1 cam with all of the MTI tuning on the PCM next time I go in for emissions. The car came factory with an EGR and AIR. I have since replaced the LS1 intake with the EGR to the LS6 without. So I yanked the whole EGR system out of the car with the AIR system. When I go into here shortly will I have anything to worry about? I know MTI will be turning off anythig that throws a code for emissions. Does anyone have the straight scoop on what the new OBDII will pick up?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
