?'s on timing with a modified LS1...
Old Aug 23, 2002 | 01:53 PM
FEAR THE LS1's Avatar
Default ?'s on timing with a modified LS1...
Whats a good adv. timing degree to shoot for in these situations.
1. Idle: ?
2. Cruising: ?
3. WOT: ?
I've been using ATAP and LS1 edit, I'm just wondering what would the best timing be for a modified LS1?
I have heads/cam/headers bolt ons blah blah...Should I just tune with as much timing as I can get away with before KR?
Right now here is my current timing* with no KR:
1. Idle = 20-22*
2. Cruising = 35-40*
3. WOT = 25*
Should I try to squeeze more?
Lee
<small>[ August 23, 2002, 01:55 PM: Message edited by: FEAR THE LS1 ]</small>
Old Aug 25, 2002 | 05:17 AM
TA/30th 1002's Avatar
Default Re: ?'s on timing with a modified LS1...
I think tuning with the knock sensors is all your going to be able to do.
If it were me, with some of your mods: I would go as far as testing with low octain gas just to confirm the acuracy of the knock sensors and to inshure the PCM's ability to drop to the low octain curve when needed. If all was ok, only then I would dial up the high octain curve and retest with high octain fuel; leaving the low octain curve as is for a safety net.
Does your timeing really run at a flat 25*/Wot curve?
Ron
Old Aug 25, 2002 | 05:30 AM
LS1derfull's Avatar
I am also interested in answers to this from people who have done it with similar mods on a low timing 01-02 car?
