I need some LS1 edit help BAD!
<small>[ August 25, 2002, 12:22 AM: Message edited by: LS194z ]</small>
One of the BCM's functions is vehicle security. I don't think it's easily bypased. The little chip/resister thing in the key works with the BCM. ... This is more than I know.
Not seeing what you've got makes it hard to help.
What about just jumping the starter relay to get it motoring over and see if she'll light!
Ron
In regards to ls1 edit, you need a serial port. Your laptop doesn't have one. You can try the USB -> serial adapters, though from what I hear you may need to try a few. i have heard the belkin unit has worked before, and B&B sells one for use with autotap - this one may also work.
Chris
