slp air temp.module with hpp3
Old Aug 25, 2002 | 08:24 PM
wicked-98's Avatar
Default slp air temp.module with hpp3
Just wondering if its safe to hook up an air temp. module with the hypertech's power tune I know that both advance timing. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Aug 25, 2002 | 08:35 PM
Johns98Z28's Avatar
Default Re: slp air temp.module with hpp3
ttt.......good question, was wondering that as well.
Old Aug 25, 2002 | 09:56 PM
FACE's Avatar
Since the timing tuner fattens up your A/F ratio it may help, the hypertech leaned me out too much.
Old Aug 25, 2002 | 10:33 PM
Fulton 1's Avatar
I'm currently running the timing tricker, HPP3, and MAF ends. They didn't like each other at first (3-4 degrees of KR), but with a dozen or so Atap runs and a MAFT I'm now pulling 28+ degrees of timing at WOT and no KR. I'll ditch it all when I get LS1Edit to let the PCM do its work properly, but for now it works well.
Old Aug 26, 2002 | 07:33 AM
1slowCamaro's Avatar
Last year when I was using the PP3 I was using the slp air temp module. I never had any problems that I knew of. But I did read something on that air temp module that said not to use it with aftermarket tuning. I then took it out. But I never had any probs. Never had autotap either though.
