Need advice on Atap readings...
Old Aug 26, 2002 | 02:18 PM
BLUEBYU's Avatar
Default Need advice on Atap readings...
Just had the LS6 intake installed and 30# SVO's by Mark at Raging Motorsports. Mark did some LS1-edit programming for the new injectors and am gettin avg. LTrims at +1.5 to +2.5 with approx. 60 mi on the new setup. Should I leave this alone or have Mark tweak it, which he said would be no problem, or adjust my MAFT to 5% rich setting on the base. BTW, I set the WOT and Base to zero since resetting the pcm. She runs extremely strong sotp and really woke up the TR224. Injector duty is now maxing out at 70% NA.
