what triggers the alternator to hi output?
That is not the case here, you can actually (at night) tell when the alternator turns from hi to low because you can hear a click (at least I can) and the lights will dim slightly.
Scott
There should be a "load wire" which goes to the alternator - a smaller guage wire, separate from the large gauge charging wire. This wire acts as a reference for the alternator and determines it's actual output (within it's rated specs). You can try putting a resistor inline to vary the voltage the alternator "sees" and artificially take it to a higher load state. You could use a variable resistor and a voltage meter to dial in what you want exactly.
Harlan could probably come up with a better way, but since the wire shouldn't be under any real load (e.g. not providing the power to do any work) I think a resistor will be fine.
Chris
Here's a circuit description of the charging circuit:
CHARGING CIRCUIT OPERATION
The generator provides voltage to operate the vehicle's electrical system and to charge the battery. A magnetic field is created when current flows through the rotor windings. This field rotates as the rotor is driven by the engine, creating an AC voltage in the stator windings. The AC voltage is then converted to a DC voltage by a rectifier bridge. This DC voltage is then supplied through circuit 1 to the vehicle's electrical system at the battery terminal.
The amount of output voltage is controlled by the current supplied to the rotor. The solid state regulator in the generator controls the current supplied to the rotor. The rotor current is a series of electrical pulses supplied by the regulator. When the ignition switch is first placed in the RUN position, the pulse width is very narrow. This causes the rotor to produce a weak magnetic field. This will produce a lower output voltage to the vehicle's electrical system. Once the engine is running, the regulator monitors the output voltage through an internal wire and changes the pulse width accordingly.
Also emailed a diagram of the connector.
You could effectivly 'disable' the alternator on 1/4 passes, so you're only winding it. Maybe even free up some ponies? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
That's 1300 watts. ~750watts = 1hp. So the most you could gain would be less than 2 hp. Wouldn't be worth the effort on a street car.
