Anyone have a flash file (ls1edit) for a setup close to mine ...?
Old Aug 30, 2002 | 09:18 PM
T/A Medic's Avatar
Default Anyone have a flash file (ls1edit) for a setup close to mine ...?
224/224 .581/581 112 w/ Stock Heads
Volant, 85mm Maf, Ported TB, LS6 Intake, LT Headers, 4" Mufflex, 4000 stall, 3.73 gears...
im hoping I can run the car with nearly stock programing, I can up the rev limiter and do basic things with LS1 Edit, but if u have something fairly close to this I hope u dont mind if I take a look at ur tuning.
Thank You
Old Sep 10, 2002 | 12:17 AM
F8L Z71's Avatar
12 Second Truck Club
Default Re: Anyone have a flash file (ls1edit) for a setup close to mine ...?
I am somewhat close in mods but I'm sure you would have to do some tweaking. I am not finished with AFR tuning yet but the rest of the car is starting to run right after I fixed my ground problem.
Old Sep 10, 2002 | 12:18 AM
F8L Z71's Avatar
DOH!!!
I didn't recognize you screen name!
Old Sep 10, 2002 | 09:40 AM
Ben99Z28's Avatar
I have the same cam, GMS MAF end, SLP LT headers with RT cats, 3" custom catback with NO muffler or resonator, the car is tuned w/ LS1edit...so far so good, just need to strap it on dyno to see what numbers it lay down but which table do you want to look at? I'd adjusted the follow stuff:
1)removed speed limiter
2)raised rev limit to 6700rpm
3)fan speed
4)removed cags
5)adjusted MAF table
6)adjusted PE vs RPM table
7)raised idle speed
8)deleted misfire code
