MIL after header install
I am new to the board and have quetion. I recently purchased and installed the TTS Long tube header package. A few days after the install the MIL lamp started coming on.. When scaned it indicated Lean O2 readings on bank one sensor two and same issure on bank 2. I have purchased the LS1 edit sofware(I have yet to recieve the software though) and was wondering of the software can solve this issue...
Thanks
Brett.
I have lid,holley filter,gms maf,ported tb,ls6 intake,b1,the tts,b and b and cutout..have scanmaster,autotap,maf translator.
About 2 days after install I got a lead O2 B1S2. and the only way I have kept the light out is to bump up the fuel trim with the MAFT. just after I posted I found a bad air pump valve and replaced both of the check valves and installed some restrictor plates. I have not recieved the same code so that may have been it.
I get a vibration at part throttle which comes and goes and after a bit it throws a MIL light. I have not had it scaned to see which code it is at this point. My Auto Tap software will not be here for another week or so. I will figure this out sooner or later..
