LS1 Edit / HP Tuners Question
Old Jan 25, 2006 | 02:21 AM
BudH's Avatar
Default LS1 Edit / HP Tuners Question
I own LS1 Edit for my car but would like to make some changes to a couple of tables that Edit doesn't address. I have access to HP tuners for a short time. If I make the changes to those tables with HP Tuners and flash with HP Tuners, will a later flash with Edit overwrite the changes with no problems?
Are the data files downloaded from the computer for Edit and Tuners the same exact data?
Old Jan 25, 2006 | 04:07 AM
gameover's Avatar
after you make the changes with HPT you should read the PCM again with edit, otherwise your old edit file will rewrite the values.
Chris...
Old Jan 25, 2006 | 10:31 AM
BudH's Avatar
But if I desired to rewrite them later to the original values, I could with Edit?
Old Jan 25, 2006 | 11:18 AM
horist's Avatar
yes... if you overwrite w/a .ls1 file you read from the PCM prior to updating those tables, it will write them back as they were in that file
Old Jan 26, 2006 | 10:33 AM
BudH's Avatar
Thanks
