new code popped up today...P0704
Old Sep 11, 2002 | 07:41 PM
black00WS6's Avatar
Default new code popped up today...P0704
Clutch Switch Circuit...has anyone ever had this code before or know what causes it?? thanks!
Old Sep 12, 2002 | 12:12 AM
jgkinsofla's Avatar
Default Re: new code popped up today...P0704
Circuit Description
The Clutch Pedal Position Switch is a normally closed switch. The PCM applies a voltage (B+) to the Clutch Pedal Position Switch circuit. When the Clutch Pedal Position Switch is depressed (clutch pedal released) the circuit is open and the PCM senses a high voltage. When the Clutch Pedal Position Switch is released (clutch pedal depressed) the Clutch Pedal Position Switch contacts close, causing the applied voltage to go low.
The PCM determines if the Clutch Pedal Position Switch has failed by not sensing a clutch switch transition. The PCM monitors vehicle speed from 0 to a predetermined speed.
Old Sep 12, 2002 | 06:24 AM
black00WS6's Avatar
so I need to check some connections around the clutch pedal? Any fuses to look at??
Anything negative this code would affect?
Old Sep 12, 2002 | 07:50 AM
9T9BlueTA's Avatar
English translation= Take the bottom panels out of the car (Like you were adjusting the clutch). The clutch hits a solonoid attached to it towards the top (you cant miss it). This solonoid is threaded so of you had to adjust your clutch farther down you can turn the solenoid and it will come in contact with the clutch again when you are not pressing it down. I had the same problem.
Old Sep 12, 2002 | 09:06 AM
black00WS6's Avatar
did your car give you any problems with shifting while the code was on?
Old Sep 12, 2002 | 01:45 PM
9T9BlueTA's Avatar
No problems shifting at all when it was on. I think it will effct the way the car runs or at least idles but I have yet to clarify this.
