Flash files
Old Sep 11, 2002 | 08:52 PM
duce_71's Avatar
Default Flash files
I was on Slowcar.net and seen flash files for different cars and was courious if you could use these files to program your pcm? I was under the understanding that the only files you coud use was the ones that were read off of your PCM. Or can you use some of the table contents in your flash file?
<small>[ September 11, 2002, 09:07 PM: Message edited by: duce_71 ]</small>
Old Sep 12, 2002 | 03:25 PM
Sparky's Avatar
Default Re: Flash files
**Only Reprogram With A Modified Version Of The PCM's File!***
You can use files of same years as a comparison and copy select tables over. The purpose for the other files is to give you an idea what other people are doing and how you can tweek yours.
Mark <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
