LS1 Edit : AIR pump?
Old Sep 12, 2002 | 07:50 PM
akw408's Avatar
Default LS1 Edit : AIR pump?
If I don't have my cats anymore, can I somehow disable the AIR pump through LS1 Edit? I see an option in there, but just want to know what others have done.
Old Sep 13, 2002 | 07:35 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Default Re: LS1 Edit : AIR pump?
I disabled the codes, and pulled the fuse in the engine bay.
Old Sep 13, 2002 | 04:26 PM
akw408's Avatar
Ahhh, there's another idea. I might just try that route since no one seems really sure how to use the AIR pump feature in LS1 Edit. Thanks.
Old Sep 13, 2002 | 05:54 PM
GeorgeC's Avatar
If you're going to do all that, go ahead and remove the AIR pump as well... I did the same as AzzHauler and had the codes removed from the PCM (waaaay back in '99 when Ed Wright did the tune).
