Pinging with lite throttle???
I was running rich and had the PCM codes for too rich.
Is the timing jumping to max at lite throttle normal? Is anyone else getting this?
2000 NBM Firehawk
MTI S2 H/C – C2 cam
LS6 intake
Mac headers
160* t-stat
<small>[ October 11, 2002, 02:48 PM: Message edited by: Kylekay ]</small>
If you are setting the rich SES lights for both banks, I would start looking into those sensors that would cause the car to change to VE mode, or alter the a/f significantly.
MAF Boofed
IAT Sensor Disconnected
Coolant Sensor Disconnected
MAP? (not sure if this sould do it)
When did the pinging start?
Your timing going into the 40's at partthrottle, is normal. Typically, without going into too much detail, your timing will start high and work its way down as you get to WOT conditions (40 to around 27).
Do you have a custom program in?
Have you installed anything that requires tuning of the PCM (ie you went to larger injectors...)?
