Correct way to delete TM?
Old Oct 11, 2002 | 06:54 PM
felton316's Avatar
Default Correct way to delete TM?
I just got LS1 Edit, so I'm tweaking a whole lot of things. I have a M6, and throughout the searches, it says M6's have TM also. What is the proper way to get rid of TM. I have a button for 'TCS Retard vs RPM', '2nd TCS Retard vs RPM', 'Max Torque', and 'Torque reduction'. Which buttons do I tweak with to remove TM? Aslo by doing so, will ASR still work?
Thanks,
Old Oct 11, 2002 | 09:27 PM
98TAauto's Avatar
Default Re: Correct way to delete TM?
under engine tab i went to spark retard limit
in there i just set my rpms in the 5400-6800 to 20 so my timing wouldnt drop below 20 degrees on the shifts... but i have a A4. Doing this keeps the tranny shifting softly under normal driving, but racing it got rid of TM <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 12, 2002 | 02:43 AM
felton316's Avatar
Is this the same way to do it for a M6? Will ASR(traction conrol) still work?
Old Oct 12, 2002 | 09:20 AM
ToplessTexan's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98TAauto:
<strong>under engine tab i went to spark retard limit</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">v1.1 introduced the Torque Reduction on Upshift table so you don't have to be that heavy handed anymore.
Old Oct 12, 2002 | 02:00 PM
Ragtop 99's Avatar
zero out the values for all columns 200 and above in the Upshift Torque Reduction Table in the A4 Shift Firmness table in Transmission.
Old Oct 12, 2002 | 03:27 PM
felton316's Avatar
I have a M6, so my values for all columns in the Upshift Torque Reduction Table are already zero.
Thanks for the help so far, still tweaking...
